configure mpls rsvp-te lsp path use profile
configure mpls rsvp-te lsp lsp_name path [path_name | any] use profile profile_name
Description
Changes the profile that the configured LSP path uses.
Syntax Description
lsp_name Specifies the RSVP-TE LSP.
path_name Specifies the configured RSVP-TE LSP path.
profile_name Specifies a profile to be applied to the configured LSP path.
Default
N/A.
Usage Guidelines
This command changes the profile that the configured LSP path uses.
Changing the profile while an LSP is active may cause the LSP to be torn down and re-signaled.
The following command configures the switch to apply the LSP profile gold-class to the LSP path sydney-bypass for the LSP aus:
configure mpls rsvp-te lsp aus path sydney-bypass use profile gold-class
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
